Hello guys,
tonight I can’t wait For this model, ( https://www.dropbox.com/s/273h40h0hfw78pn/Busto%20Pilota.stl?dl=0 ) which are ideal settings for a mail with Z-ABS? Thanks… to test new release 0.09…
:D
Hello guys,
:D
Usually with UP software, I will choose the shell feature with 10 % support and surface layers of 3. But i haven't tested the shell feature in z-suite, so maybe you will be the first in this forum :). Good luck!
shell apart ... but the other settings? ;)
How small is this?? Is it scaled right? Only about 10mm wide and tall.
Yes it’s only scaled…😉
Are you going to print it that small? If so, go with .14 or .09, light infill, 100% fan
Thanks Kyke!😉
Thanks Kyle!
No problem.. I just tried printing it at current size.. I would scale it up first.. lol
