... and then wrapping occured ... :(
Until now, I printed several parts (once per once)  without any pb.
Then I wanted to print something bigger and "harder".... like a mechanical clock.
As there are many parts, I grouped them in 4 Zcode files and started to print.
The first set of parts printed perfectly during 12 hours.
(I just have a little wrapping on the "massive" wheel, on the right)
Then I started the set "2", and after ~ 1h I had to stop the printing process because of huge wrapping.
These prints where realised with side cover panels.
I then checked the bed levelling by doing a new calibration, and launched the set "2" a second time (without side panels, for this time).
--> Result is EXACTLY the same : Big wrapping at same place.
So, yes, I can print each part, one per one, but it is not satisfying to know it is not working as it should.
Most of all, I have some very big gearbox casings to print... so I would appreciate to solve this pb.
Does any one has an idea ?
Print data :
- ABS
- 0.14mm Layers
- no support
- auto fan
- top & bottom  : 5 layers
- infill : "Solid"
http://forum.zortrax.com/index.php?/topic/483-tips-tricks-warping-issue-solution/
Reduce fan to 0% also.
Nice.
Thanks for the tips.
PS : what about Z-ultrat ? does it exist an "Ultrat juice" ?  ( :wacko: )
Z-ABS juice is fine for printing with Z-ULTRAT either. You can also use UHU Stic glue.
