Ted
January 28, 2015, 5:12pm
#1
Zsuite 0.096
Infill Light
Z-Abs
0.19
AutoFan
Bottom layer is very bad, even after been heated to remove white spots.
Top layer is also very bad, with strange gaps between path
Bottom layer :
759
Top layer :
760
761
Any idea ? Z-Suite ? Mechanical issue ?
The bottom never looks really good so anything visual should be on the top. I'm not sure about the top layer but it might help if you provide the STL for Zortrax to look at.
Zsuite 0.096
Infill Light
Z-Abs
0.19
AutoFan
Bottom layer :
Top layer :
Added to this in the bug tracker.
