Bed Problem?
I have recently experienced problems with raft curling in the back-left quadrant of the bed. The filament is Z-ABS and the printer has full enclosures. Does the bed theoretically heat evenly over the surface?
Guy
Guy
Yes.. Are you using ABS-Acetone mix on the plate? It will keep it from doing that..
The bed varies (in my experience) about +/- 3 or 4 deg C across the plate. I am getting a Lulzbot TAZ 5 soon and I will try running a print with z-abs to see what the best practical bed temp would be, just for yaks.
Can't wait to see the results.. I have seen some extra parts Lulzbot sent with printer when a friend ordered one.. I printed same part on Zortax with much better results.. Here are mine with parts that came direct from Lulzbot. I hope they have improved.. http://forum.zortrax.com/index.php?/topic/209-zortrax-vs-lulzbot/?hl=lulzbot
Keep in mind that was on original firmware and Z-suite version.. Many improvements have been made.. I should find the file and reprint again..
@Kyle
That looks great. I don't deny that the Zortrax is better for higher resolution prints. It would just be great to control a bunch of settings on the Zortrax like you can on the Lulzbot...maybe Zortrax could release a "developers" version of Z-Suite+firmware so enthusiasts could really see what this printer could do...or at least help us troubleshoot problems more easily.
Many manufacturers of 3D printers that use printed parts use fast mode on printing the parts. That way a comparison without knowing the printing parms is probably not fair.
I have seen quite strange looking parts for such printers that could be printed in much better quality with normal print speeds on that printers.
