Hi, i can't seem to get my printer to automatically install the newest firmware update. I load it on to the memory card and plug it in to my printer, but it still remains on version 0.0.5 which is what it came with. Any suggestions to what i may be doing wrong?
You can only use 2-4GB card while using bootloader.
The zortrax card that came with it should work right? I unzip the file and load it to the card and still it won't update. Also do you know why the Card has a little yellow plastic switch on it?
Switch my be in the wrong direction, it should be facing down towards the readers tabs, if it is up the printer may not see it because it was read protected or some bs that SD cards do.
