So,
When I first go the printer last week I did auto calibration and I got numbers in 0.0 to 0.1 range for all points on the plate.
Thinking I can improve (doh!) I tried the alignment process again and while I can get the back and front to be within 0.1, the middle now registers anywhere from 0.3 to 0.6 no matter what I do.
Did the plate warp? What's going on?
I heard that manually calibrating with a sheet of paper just barely catching onto the nozzle when plate is all the way up is the way to go. Should I do it this way?
Also, what is the truly acceptable margin I should be OK with here?
Thanks!
