I am having an issue with the ability to place multiple parts on one bed.
First, I cannot use the replicate feature since whoever designed it thought it was smart to place a huge gap between each part wasting most of the bed to open blank area. Useless!
Second… If I try to copy and paste, or import new parts in progressively gets slower and longer making it a 2 - 3 hour process to simply fill the bed with parts.
Is there anything I can do to solve this? I never had this issue in past versions but I can’t recall what version it was not an issue so I can try bouncing back to that one.
I am using a Windows 10 System that has way beyond the Ram and processing power needed so it is not the system unless there is something not updated that Z-Suite needs to operate at full speed.
The first picture shows the bed with 122 parts. This took me over 8-10 hours to place spanning a 2 days of work due to the copy and paste issue, or even if I import one at a time.
The second picture shows 88 parts. This was done when I realized I could replicate a group. This one took me about 45 minutes.
The last one which shows 36 parts is the native way you are asking us to do it. This places a .10 mm space between individual parts which have each their own bed… You cannot place the part closer joining the bed. I mean… come on, really?
This issue has taken me 5 days to work around to get an acceptable 88 parts to print at one time. If you want your machines to work in a production environment this has to be fixed now.
