When using the cost calculator ,what is the units ?
if I put 50 in the cost of spool is that in dollars?
thanks
-Lou
thanks
-Lou
The units are the same as what you enter into the box; it just divides the number entered by the weight of the spool then multiplies by the weight of the print. So if you wanted to find the number of unicorns a print would cost you could definitely do that. :P
That's right.. question is: what if spool weight changes... :)
