Got my M200 the other day, and have done some printing on it. But one thing that keeps bothering me and ruining prints are that the extruder studders while putting down the raft, and sometimes during prints aswell.
The teflon(?) tube for the filament guide loops smoothly and I have even tried without it and making sure the filament stays in a nice loop.
Anyone else with this problem?
I need to stand watch with the scalpel and snippers to clean away any raft that comes loose due to the sudden loss of filament feed...
Make sure the nozzle is clean. It uses an electrical connection to find zero. If you have a bad connection it may think Z-0 is lower than is. It can't force ABS out because nozzle is too close to the bed causing clicking of extruder. I normally pull off string of ABS from extruder with tweezers right before it touches bed. Make sure it not pushing down too hard on bed when it starts. It should just kiss it..
Have you checked your bed levelling and does it click when printing in a particular area or side of the print bed? If the nozzle is too close to the bed due to levelling issues it can prevent the filament from extruding and the back pressure can cause the extruder stepper to click.
Just look when the bed comes up. If it is pushing up too hard you will see the bed being pushed down. It doesn't stop going up until it makes connection with the bed. Mine does that once in awhile..
You may have loose set screws on heater element or temp sensor in heater block.. Mine did that once. I cleaned the extruder out and tightened the set screws. The pic on the right is what is was doing. After tightening screws print is on left.
