Filament wont load
There are no sensors - it's all really simple. The motor has a sharp-toothed gear on its shaft. The filament is pinched between that gear and a small ball bearing just to the right of the gear when looking from the front.
About 10mm below the gear and bearing is a small hole that the filament has to enter - this is the passage through the block containing the linear bearings. If the filament misses this hole, the stepper will click. At the end of the passage through the bearing block is the feed tube which is part of the hot end, and at the end of the feed tube is the nozzle.
There must be a problem with the stepper motor then. :(
I emailed support yesterday, but nothing back yet.
I might post a video when I get home.
Video of my problem.810
018.MOV
Did a little bit more fault finding, and it turns out that the main ribbon cable is faulty.
When it is sitting normally, all the way home and latched, the extruder motor does strange things (oscillates, goes backward, etc).But when I flexed it a certain way, the motor came to life.
I have sent a mail to Zortrax to see if I can get a replacement.
Thanks for all your replies.
Nice job,
while waiting for a new cable, look for similar problem here on forum,
someone wrote how to repair it for your own
I did. :smiley:
Here…
http://forum.zortrax.com/index.php?/topic/414-my-printer-not-printing-upper-left-part-of-printing-model/page-2
Unfortunately, my ribbon cable is different from the one Andre shows. :(
New cable should be on its way! :)
Can you post a picture? How is it different?
I will try and post a picture later. :)
Picture of the cable that came with my printer.
But how does it look right at the connector?
it might simply be that they changed to a black ribbon cable...but then you could still do my repair. the color of the cable does not matter...assuming it is still the same connector style.
It is a different style of connector.
I am guessing you have figured this out as this is an old post. But heres this anyway. lol
Cheers
Did you take the feeder motor out to see if there is filament blocked in the top hole? I had to drill out Zglass there before a few times because it broke off when changing the filament.
