With firmware .0.4 platform heating will often stop around 95% and slowly start regressing backwards, and never reach 100%. Sometimes it works but I don't see a particular reason why. I just need to restart the machine until it does. When it does reach 100% it takes a LONG time.
When I use firmware .0.3 it heats right up, quickly and every time. Anyone else experience this? Is there a fix? I like to be able to use the pause functionality and other improvements in 0.0.4.
I haven't had the problem where it starts cooling again but I have noticed it takes longer to heat up.. Also it appears that the nozzle doesn't heat up until after the platform heats which makes it take longer to start printing.
Good to hear it'll be fixed in 0.0.5. Looking forward to the wifi ability too.
Same issue here. Rafal said it will be fixed with 0.0.5.
Do you have a process you follow when it doesn't heat up or do you just try again until it does? It's frustrating not knowing how long it'll take to get a print started. I wonder why it seems to only be an issue with some machines?
