I tested eiffel tower.
http://www.thingiverse.com/thing:53279
End Times are 8:43…
I set fit max high from zsuite.(maybe 190mm)
when… 99%
I saw working…
It printing same level : From top near 5mm.
Maybe M200 possible high limit about 185mm.
Pls check this issue.
I checked
after complete… bed can’t down.
check by ruler… complete model…(It is about 185mm)
Have a nice day.
P.S. And I failed… because auto surpport… very difficult for remove surpport.
Don’t try eiffel…^^*
Check platform calibration knobs unscrewing it too much decrease build height and I think that software just now do not count raft height at time of model placement this is around 2-3mm.
[quote name=Martin Olchanowski]Check platform calibration knobs unscrewing it too much decrease build height and I think that software just now do not count raft height at time of model placement this is around 2-3mm.
[/quote]
Thank you Kindly reply …Martin…
User must can set lower than max high.
Have a nice day…
That’s a good point to check when printing tall objects. I thought about printing the Eiffel Tower too but I saw there was going to be a lot of support so I decided not to print. I think when they have the Support Lite feature it won’t be too bad though.
