Huge dimensions problem
Hello again ;)
I habe big problems to get the right dimensions on my printed part.
The part i printed is attached to this thread. I need this for a customer, really quick. I have been testing around, but i have no solution for this big problem.
So here is my big problem... :rolleyes:
(Bottom Part)
This part has a constructed inner dimension of 45,5x50,5 and a wall thickness at 1,6mm.
So the outer dimension is 45,5+1,6+1,6= 48,7mm and 50,5+1,6+1,6= 53,7mm
Ok... so far so good. I printed this part with the settings i attached to this thread.
Then i measure the dimensions and what i get is very very bad.
For the inner dimension i get 45x50mm (0,5mm difference !!!!)
For the wall i get 1,9mm - 1,98mm
And for the outer dimension i get the right measure?!
Hmmm.... if the wall were at the right dimension, the inner dimension will be right too.
Why is this happen? What can i do? I think the Z-Suite software is doing something wrong...
I can change the dimension in the CAD, but thats not so easy, because i hurt other solids/dimensions. I constructed this part in Solidworks. Are there any options?
What can i do now. I need this part really quickly for a customer, and by the way i expect more from a printer with that price range.
3412
3413
Heissner_Unterteil_V2.STL
Thank you in further
Felix
Intressting we have the same Problem we lose 0,5mm layer when we have a part +/- 40mm high ?
Oh... 0,5mm in Z Axis? Thats very bad.
My parts are a little to high 0,1-0,15mm.
The printer puts an excellence surface out, but i need the right dimensions, than a good surface <_<
Zortrax support... can you support us and give advice how to handle dimension issues?
Can u give us further information how to construct a model that the right dimensions are printed well, or how the Z-Suite slice the model?
