Well I've been holding out for a while so here's a little glimpse of what I've been printing.
Would of printed everything already if my Zortrax didn't break down <_<
This part has to be reprinted unfortunately -_- I had it turned slightly and it threw off the dimensions
Had to glue these two pieces together as it was two big as one piece to fit on the bed
2 minutes of sanding with 240 grit sand paper and a hit of primer just to see how much sanding for the little amount of time does
Part that has to be reprinted but thought I would at least hit it with the red I think I'm going to go with for visual comparison sanded with 240 grit sand paper for 5 mins 1 coat primer 2 coats dark cherry red.
.09 for the face place and .14 for everything else. One print was 60 hours which is the one that has to be reprinted again and that was printed at .14 the .09 layer height was almost 80 hours
Version on the zsuite or the Iron man mark number?
If it's the zsuite it was with the latest except for the face plate that was 0.8
if it's the mark number it's located in the title the mark 3.
I do have the link however the stls provided have tons of issues and I don't recommend printing from them. I'm still working on tweaking the files as I have already printed to much to restart but there is some alignment issues with the originals so it's making it a pain to deal with
Thanks. I meant the mask. There are a few different Mk3 ones on thingiverse, but it sounds like this one might be one to avoid, at least until the parts are repaired and aligned.
Yeah I was a little frustrated when I spent all that time printing and the pieces didn't line up
