Junk printed on the last 3-4 layer
Hello I need help. I'm trying to print this Caps and I get junk printed on the last 3-4 layer.
Please see picture before and after.
I have tried 0.9,.14.19 , solid....
I always get the same.
Thank you
The top lip is too thin. If you use the advance settings outer contours button and raise it to .1 or .2 it should work fine
Minimum sliceable wall thickness is 0.45mm for high poly models and a bit more for low poly models.
Your model is 0.36mm thick at the top.
Thank you so much.
