Large print
This is probably the largest print I have done on my m200 taking 37 hours. It is part of the Mr Walthersnap figurine from Bold Machines (http://www.thingiverse.com/thing:457242) and I am very pleased with the way it came out.
I had to use the slice feature to slice off the bottom 1/2" of the piece as at two times the scale it was higher than the m200 print envelope. I printed the two pieces separately and glued them together .
I have already printed the Margo figure and I am currently preparing it for painting.
David
354
awesome !
Here is the jacket primed and ready for painting. The second image shows some of the other parts printed.
Looks perfect, impressive!
Thanks. Jose Alves da silva models are great and very well designed for printing with either no support required or with built in supports. A great example of model designs for 3d printing.
Coupled with the superb quality printing from the m200 produces some of the best prints I have seen.
David
Mr Walthersnap is finished. He stands about 12" (30cm) tall and is made from 11 individual prints.
Margo the hero of the the story is not far behind and I will post pictures once finished.
I am also working in Margos dog and one of the bridge workers.
David
Wow great job!
Where are you located in California?
Yes, I’m in Southern California.
very cool!!
Magnifique !  :o
David, may you share with us the painting technique are you using ?
I have been printing all the parts at 0.14 layers except heads which I print at 0.09.  Takes a lot longer but aids in ultimately getting a finish that pretty much hides the fact that its 3D printed and therefore requires less finishing work.
First I give the model a quick sanding in any areas which obviously show the filament strata .
Next I spray with clear Deft sanding sealer and once dry sand again.
Then I spray with Rustoleum 2in1 filler and sandable gray primer and sand again.  Any visible bad areas (very few on the m200) I then fill with Tamiya putty, dry and then sand.
Then usually another cost of 2in1 filler if needed.
Final fine sanding then a coat of Tamiya fine primer.
Then I (mostly) airbrush acrylic paint (I use Golden fluid and high flow acrylics) which I thin as needed.
Then a final coat of Testors dull coat to protect.
Hope that helps.
David
Great work. I like how you left the layers visible on the fingers. Looks like a real finger print! Lovely work.
Here is Margo.
Her head is attached to the body with magnets so I can remove it. I may paint another print of her head as I am not totally happy with the current painting.
David
Absolutly fantastic work!. David, if some day you decide to film all your working process i would love to watch that movie!
Marvelous  :o
How time and sun pass over your prints ? did them be distorded in time ?
your painting skills are first class I’m very impressed good job if I can’t paint it with a spray can my things don’t get painted
Marvelous :o
Your thinking of PLA, ABS can take the sun for the most part you would have to get the print to 160 to 200 degrees ferinheight to start warping ABS
There not Z-PLA yet, Yes I think about UV influence more than temperature, ABS can become "brittle"
Very true unstabilized ABS is notoriously bad with UV exposure, If the ABS has been compounded with UV stabilizers it doesn't become as brittle but most filament doesn't contain UV stabilizers.
I've never noticed any issues though with my prints that are outdoor.
