Hi everyone,
There are a couple of surface mount led’s on the underside of the heated plate, can anyone tell me what they are for?
Out of all the prints I have done, I have only seen these led’s on once.
Should these lights be flashing all the time during printing?
What connects these lights? Have I got a dodgy connection?
Andre
#2
It’s on solid during warm up and flashes rapidly when the plate is hot.
OK, thanks Andre.
Mine is not working then.
Do you know which connector functions this?
Andre
#4
It should be the big one. Is it getting hot? Maybe you just have a bad LED?
Yes, the plate is heating up.
There must be some connection issue, as I have seen the led’s on during one print.
I will have to investigate. ðŸ˜
Quick fix until the surface mount led's I have ordered arrive.
Top led track was broken, and bottom led had a bad solder joint.
Andre
#7
Oh…didn’t realize there were two LEDs… I wonder why there are two needed?
