Hi, I just received the printer (HW version 04) and I am getting the following error when I initiate a print
"File Error"
"Please prepare your model again"
This is not an occasional error, it happens on every instance.
I tried different SD Cards, re-format them and the outcome is still the same.
However, if I just go back to the main menu, attempt the print again it just prints perfectly. Every retry is successful.
I get this error on every first attempt. The error appears right after the machine heats up the extruder.
What can I try?
Other than this issue the printer appears to work perfectly. I was able to update the Firmware to 1.0.0, the calibration was successful and I am able to print just fine (on the second try)
"File Error"
What can I try?
Thanks,
Diego.
PS See attached images for a pic of the error
I had the same problem on a customers machine, brand new. Never prints the first time, same message as yours pops up. I turn the printer off and restart, then all is OK. Will try your method next time.
