M200 Heated Bed resistor spec needed
#1
Hi!
My heated bed has shat itself and blown a SMD resistor. Im a student so I’m not too keen to replace the bed and would rather fix it with another cheap resistor. However, since its blown or disintegrated, I am now unable to read the usually legible white resistance indicator printed on the surface.
Would someone be so kind to reply a picture of theirs, please? or supply the spec? :grin:
Cheers!
#2
Hey there!
Hope this helps :slight_smile:
Please, remember to always unplug and plug heatbed cable with printer turned off.
I recommend that you examine the cable and motherboard for any signs of damage or burn marks as well.
#3
Thanks Marta! You’re an absolute champion.
Great idea. Ill keep all that in mind when I swap it out :ok_hand:
#4
It worked! Ignore my terrible soldering skills please :neutral_face:
Autocalibrating and printing just fine :ok_hand:
Thanks again Marta!
