Occasionally I get this weird display reading when turning on my M200 with SD card inserted. This has been happening for a month or more. Should I be concerned? Anyone else seen this before?
Its probably cable or LCD display itself, if the printer is under warranty, we can replace it, if not - buying new set seems like only option.
Hi Marcin. Thanks for the quick reply. I purchased new last November so am fairly certain my M200 is still under warranty. How can I determine which part is at fault? Thanks!
If you got more than 1 printer, you can swap parts between printers (one at the time), if not - its easier to replace whole 'module', we are selling/sending it as a unit so no big difference.
I just have the one machine. Ok, I thought maybe they were sold or supplied as seperate parts. Well that makes it easier.
