hi
my zortrax not working
hi
Tareq, look closely at the small connector on the perfboard. Check for short circuit or broken contact.
Its most likely Ribbon Cable / Heatbed, first you can check all connections between motherboard and both - extruders PCB and Heatbed itself but if that wont help - replacing would be only option.
Thank you
:D true i fix it
