The Z axis stepper motor is missing two screws. This machine is only a couple of months old, so they were not installed at assembly time. I can't find M3 -30 mm screws locally. I need these screws PDQ.
Guy
Guy
McMaster-Carr will have them to you in a day or two from their LA location:
Thanks MichaelHenry,
I bought this printer from Octave. If they can't send some I'll order from McMaster.
Guy
also mine have only two screw
Guy
Just hit Ace Hardware or similar.. WAY cheaper than McMaster.. If you insist on ordering online, boltdepot.com is great.. I have used them many times.
Mine too. V4 with only 2 screws. If anyone can give any guidance on how to access/install as don't fancy removing all the stuff sitting above them. Thanks.
All new printers only come with two. It shouldn't make any difference on print quality.
