I really want to love this printer.... but it's driving me nutz. I think I've gone through just about every version of Z-Suite since beta 0.0.6 up to the latest, but the strings and burns just continue. I'm fairly new to the 3D printing, but have been in the 3D industry for 20 years so I know a little. But try as much as I can I can not get rid of this problem. I have tried different Z-ABS spools & Z-UltraT. I feel as though my printer is running too hot? Lower temp profiles seem to help slightly, less burns and stringing....Anybody have any ideas?
Z-ABS, 0.14mm, Quality High, Infill Solid, No Support, Fan100%
I agree with printz, Love cleaning my nozzle or replacing it because the print quality does improve. Believe it or not but Zortrax states you should replace your nozzle after 1 full spool.
If I was selling nozzles for $30 each, I'd want you to change them after each full spool, too.
Thanks for the replies everyone....appreciate that your all trying to help!
I purchased the M200 November 2016, brand new in box from reseller here in Australia. I purchased a second nozzle as a backup for when I clean the other, which I have done multiple times for 24 hours in acetone. Also checked with the supplied wire to make sure they were clear. No change to anything print wise.
Can you post STL? That might help. I have two machines here V1 and V4. I'll print on both to test.
Which version of Z-suite (and firmware)? The infill Solid option was changed to infill Maximum sometime ago.
I am running more tests now, back on Z-Suite 1.7.2.1 and 1.0.5 Firmware. I will post more as I progress with better notes. As I mentioned, I have gone through most versions of Zsuite without much change. I think 1.3.0.
beta0.0.6 and firmware 1.0.5 gave best results as far as I could tell.
Here is the print off of the V4 printer. 67 hours on printer. (same settings you posted) .014, full infill, auto fan 1.7.2.1 Z-suite. I am running 1.0 Firmware though. There is some stringing,but not much.
