No Display light
Hi at all,
my new Zortrax has no light on the display.
No answer from Support :frowning:
What can I do?
Do you mean the led illumination or lcd?
The LCD Display …
Can you take a picture?
of course!
Did you buy it from Zortrax or from a reseller ?
It may be something simple like an unplugged cable or on the other hand something broken, but in any case, I think you will void your warranty if you try to repair it by yourself without following a Zortrax support procedure.
Which way did you use to contact support ?
Some user encountered problems with online form, but I contacted support by mail and it worked well.
Laurent
the Printer is from Amazon.de
I will check all Cable tomorrow.
I use for contact the Webform, because I found no Mailadress.
(sorry for my poor english)
Before opening the printer, please have a try with mail too:
support@zortrax.com
Your printer is brand new, do not do things that could void warranty
Laurent
You have to turn it on!
Sorry…I know…I just could not resist! :smiley: :smiley:
You could check the ribbon connector on the LCD board and the main board. But get with support first…they can send you instructions.
