I had a detailed post typed up, but when I went to submit it it crashed... Oh well.
The hot end that I had to install after this problem occurred once was purchased directly from zortrax for $75 (plus shipping). It had less than two weeks use, with under 8 hrs of printing. For those who don't know it clogged about 98% of the way through a print.
I tried what I could without removing the nozzle, using a wire to clear the nozzle and then re-feed the filament, which actually worked OK. I then proceeded to print another model and this time it jammed after about 4 layers.
I heated the hot end as instructed and proceeded to remove the nozzle, but unfortunately it snapped at the shoulder where the nozzle meets the threaded portion (I tried to get a decent picture). I suspect this was overtightened in the factory, and the problem only arose when the nozzle had to be removed. Again this was a new hot end, less than 2 weeks old.
I was told by support that mechanical issues are not covered under warranty, and I am SOL. All that I am asking you to do (zortrax) is mail me the small aluminum block (not an entire hot end) as I already have a spare nozzle, and can reuse the thermocouples.
I tried to get a few pictures, you can see the nozzle snapped in the wrench
[URL=http://s343.photobucket.com/user/72monte350/media/photo34_zpsc9a7eadb.jpg.html][/URL]
[URL=http://s343.photobucket.com/user/72monte350/media/photo27_zpsc0a844e0.jpg.html][/URL]
[URL=http://s343.photobucket.com/user/72monte350/media/photo17_zpsaec9022f.jpg.html][/URL]
