Hi guys,
just received the Zortrax yesterday and been printing all different part,
for some reason, I have an issue with some print, see the picture in attachment, not sure where that can come from?
any idea?
using Z-ABS - Blue
Hi guys,
any idea?
using Z-ABS - Blue
Have you tried different orientations? or random seam instead of normal?
I see that often myself. Be interested to hear what the more experienced users have to say about it also. I have never tried "random". Always left the setting on "normal". I will try that.
here is the result with a new print:
Normal speed
0.19mm
Random seam
Solid infill
that worth, not sure how to fix that
I did print 6 pcs of it to have a longer time between layer and get it colldown but that didn't help
Defective nozzle?
Contact your reseller, seems like you bought a broken printer.
Move the head to the center and wiggle it… Does it have a lot of play? Do an axis maintenance, check all set screws, make sure the bearings in the head have snug set screws (do not overthighten!) also try a new nozzle…if the filament string curls coming out of the nozzle, then this can hurt wall quality.
