I had a weird thing just happen to me.
I was printing the second part of a print and while I usually place the objects on the right or front side of the bed, I used the left side this time.
I checked on it and was printing beautifully. Then I went back when it should've been done-1.5 hrs later, and the printer was in idle on the print object. ( it didn't go back to go position or drop down...it just stopped. It wasn't trying to extrude so the nozzle wasn't clogged.
I figured it was just a corrupted Zcode somehow and got a pause inserted in it but it didn't go to home position.
So I just redid the file and started it up again. Started perfect and doing well but will see if it was just that position-as the cable was just redone last week and prints perfectly.
Thought maybe someone else had this error before and knew what happened.
Cheers and thanks
