Hi im new here! im interested in translucid colors…someone can recomended wich ones?? and tips to posptroduction cleaning after 3d print??
“Crysta-Line” ABS: http://3dprintergear.com.au/premium-abs-/207-crysta-line-topaz-blue-175mm-abs-1kg-22lbs.html
I have it in yellow, blue, and red. Works in Zortrax, will be even better when we have temperature control. Taulman T-Glase is also available in translucent colors but I have not tried it in the Zortrax.
As you cited Taulman, what is the difference between Taulman Nylon 618 and 645.
[quote name=venosa]As you cited Taulman, what is the difference between Taulman Nylon 618 and 645.
[/quote]
618 was the first one. It is more flexible than 645 and less transparent (more “milky”). 645 is stronger, more rigid, more transparent, and warps less. I generally prefer 645, but each has its uses and both are very strong.
Julia
[/quote]
Julia
