Hi i've just changed the small connector yesterday and everithing went fine i did some test prints. But today i've noticed that the platform didn't heat up even when loading the file just the heating extruder screen apears is like the printer doesn't recognise any platform I also noticed that the blue led under tha platform only works a bit at the start and then stops. Anyone has an idea of what could be wrong?
I would suspect the connector still. I’d recommend unplugging it and using a multimeter to check for for continuity between the pins; if any exists you have a short somewhere.
Mine did that the other week. The tape underneath the bed was loose. I pressed it and it's been working fine. Not sure if that's your issue.
Cheers
My tape is a bit loose too, also has some sort of dirt inside.
I would suspect the connector still. I'd recommend unplugging it and using a multimeter to check for for continuity between the pins; if any exists you have a short somewhere.
I did'nt have a multimeter. Finally i've decided to get the full wire insted of doing some DIY aberration on it everithing started with the problem of the platform hiting the extruder and then i found some wire broken it's why I've decided to replace them to see if the problem solves. As soon as I have the wire i'll to check if it's the problem i'll post here.
problem with my platform: she starts to heat up to 80% more then anything stop ... back to the main menu. I am willing to change the connector but where I can buy?
Hi Chris i did't just this morning the wire arrived but the problem persist there are two sockets on the board maybe i've just plugged the wrong one is it harmless to check or better wait for instructions ?
