Hi People, today i printed 2 pieces 5*... and on the third print my printer started doing bad prints...
Here is some photos what is happening…
Anyone can help??
I tried with these settings:
-1st - 0.14 ; High ; Solid ; Fan: Auto
-2nd - 0.14 ; Normal; Solid ; Fan: 100%
The software used is 0.9.5, Black ABS…And the STL is attached…
988
A_baseEscv2(2)_40m_5g_R0.14_SOLID.zcode
Thanks,
André Carvalho.
Andre
March 9, 2015, 12:01am
#2
did you try a new nozzle?
Now i don't have nozzle's in stock...
If someone can print them is just 4g… it’s a small piece…
Here is the file…
989
Kyle
March 9, 2015, 12:13am
#4
Looks like the parts don't have time to cool.. Try printing 2 parts at the same time. Put a little space between them on the plate.
Yep, i think the pieces don't have time to cool down, but some months ago i printed standoff's 6mm and this don't happened..
I will try with 4 pieces…
Thanks…
Kyle
March 9, 2015, 12:27am
#6
If you look at the code, the wall is only 1 layer thick with no room for infill. That might cause a problem. Not very strong. You could probably use .19 as well. Minimal loss in surface quality and faster.
Hi, ok very thanks i will see that and try..
Very thanks, more opinions are welcome…
Best Regards,
André.
