Hey All
so we have intressting thing we have a projekt for a castoumer and we printet a part high40mm and a feed 20x20mm
we print and messure after 20min
the feed 20x20mm is ok bad high we lose >0.5mm is thah in tolleranze ? and normal ?
Hey All
Hi
I have issues with the tolerances too... in height i have 0.1-0.2 mm to much.
Are the other dimensions of you part are ok?
Can you post the settings in Z-Suite...
what hardware version are you guys using? sounds like it could be what i had with my hardware V4 with the z dimentions off. they fixed it in the latest update. but now im guessing it has disturbed people with previous hardware versions - if this is the case, then i feel your pain.
we have 4xPrinter V4 and Software V1.6.1 for Windows
so now is ok
delete file and start white a new STL file import to Z-Suite 1.6.1 and Print Again new is ok
