I need to print a piece but unless i print it with 0.09 Z resolution (8 hour print) it fails to complete the slicing:
Original piece:
[URL=http://minus.com/i/DcQm95eCpATK]
[/URL]
The slicing always stops at 66%:
[URL=http://minus.com/i/XYuZG3kg6tye]
[/URL]
The print settings are:
Layer thickness: 0.14mm
Speed: High
Infill: FULL
Support: 40
Seam: Random
Surface layers: TOP 5 , BOTTOM 5
Andre
#2
Try without random seam…I think there’s a bug still
I had that happen to me
i need to use random seam forthe pieces to fit tightly
Kyle
#4
Cut off the top and print just print that with normal seam to check the fit.. It might be OK..
I think i have already done enough tests :P
[url=http://minus.com/i/4rHdRQkLXFgx]
[/URL]
the best fit i can get is with 0.09 layer resolution and Random seam
File a Bug Tracker report.
Did you try to repair the STL file using the online Microsoft service: https://modelrepair.azurewebsites.net/
It could solve your problems...
