I wanted to print a custom case for a Cubieboard2 with CubieScreen.
I started with a Case for a normal Cubieboard and got a print error / problem with the example print.
I adapted the original model / redesigned the top-lid to be deeper, added the cut-out for the display and - surprise - i got the same print error again. So is this a design error on the model, or a Z-Suite problem? Any ideas?
I was surprised to see the same print problem on my modified design which was recreated from scratch just doing
measurements in the original stl. So my printer doesn't seem to like the geometry, though it looks ok when i look at the ZCode with the "Timeline Slider".
Hm, i am not 100% sure but i think printrun #2 was done with a different nozzle, no brand new never-used one, but a different one. It looks a bit as if it "forgets" to print the outside and you are directly looking at the infill.
Well i guess if i get rid of the phase and go with a minimal 0.5mm radius instead the problem is gone, but then i have to remodel the complete bottom part of the case as well to match the top and i am lazy :).
I have almost given up on this for the moment. (And still have not printed the Z-Code from Z-Renegade.. Shame on me.)
This one is printed with 0.19mm and Light infill orientation 45degrees, so that the side with the cut-out faces the front left corner of the printer
2855
This one has the phase removed printed with 0.19mm, Mediam infill, orientation, that the cut-out faces the RIGHT side of the printer.
2856
Yeah everything fine - or is it? Unfortunately not:
2857
So what do i know now? Orientation of the model on print-plate affects on which side the artifact shows up.
If the cut-out is facing left. I have them on the outside. If it is facing right, i have it on the inside.
Like this:
2858
2859
Still not conclusive if i have a HW or SW problem...
Maybe i should try having the cut-out face to the front or back?
Ah well i give up for the moment and throw the Cubieboard back in the Box where it already sat all year. Maybe a fresh try in summer or so, with a complete self-designed case and maybe
design it a bit thicker. Everything else i printed so far came out ok, so this one is a bit of a puzzler.
