I'm in need of some cases that are bigger than the M200s build area, that's why I designed a case that's built of several parts with the main body being 2 parts.
I am not satisfied how the parts fit together and fear that I will not get it better because of different shrinkage at the connecting areas in the middle.
Is the seam in the middle the top of both parts or is it printing in a horizontal position as shown? I hope the ABS holds up to heat of those tubes.. ;)
You're right, the seam is the top of the part the way I printed it.
The tubes can be touched without getting burned, should be no deal for the ABS case.
