Quick question - should it move or not ;)
Recently my printer started to generate some never heard before noises so i started to observe the mechanism and found that two black rings on rods moves (market with red lines on the picture) while the rest are not. Can someone check is it normal?
Short recording:
https://dl.dropboxusercontent.com/u/4106741/WP_20150701_003.mp4
should not move, mine don't.
http://forum.zortrax.com/index.php?/topic/1716-bearing-coming-out-of-housing/
Thanks for reply.
I should write "rotate" instead "move" - it's not going out or something like that but it rotates according to printer moves. Any ideas how can I fix it?
Short recording:
Hello
Please contact our customer support team regarding this issue: support@zortrax.com . Please add a video to the report, it will help us during the investigation of the problem.
Looks like the cover for the inner race of the bearings are moving along with the inner race, this is not usually an issue depending on the design of the bearing, some have the cover pressed into the outer race so that it moves in relation to the inner race and some are pressed onto the inner race and move in relation to the outer race of the bearing, this last condition seems to be yours.
The cover is designed to keep out contaminants and will turn in relation to one of the two races, inner or outer, most designs are locked to the outer race, I could not hear any noises in the video but if you suspect the bearing is having issues then follow all prescribed cleaning adjusting and lubing directions from the manufacturer.
London weather forecast april London, United Kingdom weather forecast and weather conditions. Today’s and tonight’s London, United Kingdom weather forecast plus Doppler radar from. Get the London weather forecast.London weather forecast april 2017 The climate in London Located on the River Thames, London is the largest metropolitan area and. London, United Kingdom 8:32 PM BST on April 08, 2017 (GMT +0100) See full-screen radar on WunderMap. See full-screen satellite on WunderMap.
http://xfb38060.bget.ru/777/gidrofobizator-dlya-kirpicha-germaniya.pdf
http://xfb38060.bget.ru/777/gsk-1-gidrofobizator-kupit.pdf
http://xfb38060.bget.ru/777/gidrofobizator-tiprom-k.pdf
http://xfb38060.bget.ru/777/gidrofobizator-neogard-2-1.pdf
http://xfb38060.bget.ru/777/gidrofobizator-rosa.pdf
slovo-gidrofobizator.pdf
I just LOVE weather reports!!!!!!!!!!!!!!!!! Maybe I'll just look on here instead of watching the news!!!!! FIX THIS!!!!!
подарок ребенку на крестины
