Do you draw in inches or mm?
I use metric. It's an old habit from back when I was using Repetier-Host.
Sucess! Had to redesign it from scratch after prototype 3 almost killed my motors when it got sandwiched between the printbed and SD/LCD protruding piece thing (technical jargon, I know :P ). Z-HIPS, .14mm.
Looks great!! I guess you are sticking with DS then.. I was going to tell you that you can set it to export STL in mm if you draw in inches like I do..
Thanks! And thanks for pointing me toward DS, it’s really easy to use and all of the tools just make sense.
Thanks! And thanks for pointing me toward DS, it's really easy to use and all of the tools just make sense.
No problem.. I wish more people used it. They did make it pretty easy. If you ever upgrade to Spaceclaim you will already know most of the software.
