Really bad printing at certain height
#1
Hi , please look at he pictures , the M300+ was printing beautiful , but in several occasions and around the same height (even different materials - same part printed) it started to get really bad (underextrusion) any idea what causes it? or how to solve it?
thanks.
#2
Hi, @userksh14.
Please, check if all cables are properly plugged into the extruder PCB.
It looks like something hooked against the support structures on the right, so I recommend that you make sure whether heater&thermocouple is properly connected to the hotend (as in this instruction).
#3
hi thanks
everything looks ok , the issue seems to be just at certain height , two print fail approximately at the same height ; what else could be?
#4
attaching pictures , maybe I’m missing something
#5
hi , tried to load some material , and the gear started to click , you think this is also caused by a bad extruder cable?
#6
I don’t see anything wrong in the pictures. As for the cable - have you managed to load the material past the extruder gear? When does it start to click?
#7
hi, right in the beginning ; first I tough it was the filament , then I pulled back a little (not touching the gear) and it started to click again ; the tried again and now it grab it without clicking.
#8
I’ve sent you a PM, please check your inbox.
