Sure. Here's the entire contents of the SD card (attached) - the rook file and the 1.0.0 firmware (I upgraded to 1.0.5 off the Zortrax web site; printed the rook with 1.0.5).
FYI, I bought the machine in the USA from an eBay auction - this one:
I had the same rook on the sd with one of my Zortrax machines, I gave away the rook to someone but I dont remember seeing a droop like that. Printed nicely.
It only did it in that one spot on the rook (plus the infill in another model of my own).
Other than that the rook was absolutely perfect. I was extremely pleased with the first-try print quality.
But I'm a bit of a perfectionist, so I posted about the droop. In that one spot.
It has to be Proshare putting that model on SD card. I've found it on Thingiverse.
It looks pretty similar but I'm wondering whats hanging there, if you look at 3rd attachment - there is nothing that could be causing that kind of loose string.
The zcode models look slightly different, but not in the place where it's drooping.
I think the filament (um, "material" :-) is not cooling fast enough, so it sags under gravity until it solidifies.
I wonder if it matters which way the printhead is moving, because the fan is only on one side.
Sure there is.. Look at that layer. The outer shell goes in and out with no support. I'm guessing that is causing the droop.
