I don't know how large the piece is but I think you will have a much better result if you print it on his side.
And if not possible try to cut the part in a few pieces and try to glue it afterwards. (Sorry guys this meant to be a reply for another thread - So in your case Trigger you don't have to do this)
BTW, top and bottom layers are mostly not so nice looking as you would expect. (And certainly not on a M200) But increasing the setting of the amount of surface layers on top and bottom mostly give a better result.
It looks nice and normal to me but if you want something better you can try to sand it with a sandpaper 600-800 degrees and then apply heat with a gun heater to remove the scrapes.
I dont think there is a printer that can do better surface finish than the zortrax and this surface looks nice to me, at least from the photos. To avoid uneven surfaces in a big flat part with holes you must print that part upwards as samba mentioned above.One other thing you can try is to print it as usual but with fan speed at 20% or totally off.
My first post so hello to everyone. I'm totally blown away by how brilliant the M200 is but I have one slight problem which Trigger also seems to be having.
I have the same problem with the ridges on flat surfaces. I am using Z-Hips. It looks to me as if its more prone to happening at tangents to holes.
I have an Ultimaker 2 also and its surfaces are almost completely uniform. There are occasional marks with the Ultimaker but they are just cosmetic, the ridges with the m200 stand proud of the surface and you can feel them with your nail.
The ridges are not insignificant and it would be nice to get to the bottom of the problem.
[url=https://flic.kr/p/GgzEpL][/url][url=https://flic.kr/p/GgzEpL]IMG_3666[/url] by [url=https://www.flickr.com/photos/41034110@N06/]jamesscotland73[/url], on Flickr
[url=https://flic.kr/p/GgAvjQ][/url][url=https://flic.kr/p/GgAvjQ]IMG_3669[/url] by [url=https://www.flickr.com/photos/41034110@N06/]jamesscotland73[/url], on Flickr
[url=https://flic.kr/p/GaJbao][/url][url=https://flic.kr/p/GaJbao]IMG_3668[/url] by [url=https://www.flickr.com/photos/41034110@N06/]jamesscotland73[/url], on Flickr
I also see this problem. I just recently printed a bracket with some holes. I no longer have the print, but still have the STL and zcode that I used. The top surface has lines and unevenness.
I also see scraping of the plastic, when moving the head diagonally across the just printed layer. (all materials, any layer height, fan = auto, brand new V4 M200)
and I also see uneven top surface. (see picture)
You can see that ALL the uneven 'lines' start at the edge of a hole.
worst with ABS, best with ULTRAT :
in picture, all parts are ABS (FULL or SOLID fill), except :
This has been an issue for a looooong time. I think Drew once posted an explanation of why it happens, but it didn't seem to help get the problem corrected.
