It start happend three month ago, I was using both a early version of Z-Suite and a more recent one.
Recently I updated to the last version of firmware and of Z-suite but the problem still appears.
4256
The shifting is always on the right and of the same distance.
Marcin
#2
Do an [url=http://support.zortrax.com/axes-maintenance-m200/]axes maintenance[/url], should do the trick
HI,
I did the axis maintenance but the problem remains.
The problem arise randomly , one time every 5 - 7 prints .
Well , I have found the reason for axis shifting.
Especially at the beginning of print when the raft is created the M200 send rapid and wide command to move .
Then I can hear a quite loud and short noise coming from stepper motors and the shifting of axis happens.
With a good amount of grease on the axis the problem has disappear.
