On of my main reasons for considering a move to M200's was to gain the temperature resistance (and affordability) of Z-ABS. I took delivery of my first M200 less than a week ago and am still diligently testing. Today was a simple heat test with Black filament. PLA was printed on a Replicator 2…….. M200 for the Z-ABS.
45 minutes in a car in direct sunlight. Temp rose from 72 degrees to over 120 degrees f and the PLA product became soft to the touch (two fingers of pressure) while the Z-ABS stayed nice and rigid with no deformation. I'l give it several more hours and check again but am very happy so far!
Initial setup and temp. 350
45 minutes later on a 57 degree day in Denver. 347
PLA on the left and Z-ABS on the right. Deformation from 2 fingers of minimal pressure on the PLA. Nice and rigid still with Z-ABS 349
Same results with second set of test samples. Z-ABS left and PLA right. 348
You can buy almost any opensource machine and print PLA without problems, they are half the price of zortrax and results are fine with fine tuning.
Or I can wait for PLA and not spend the money on another printer.. That would make my wife MUCH happier.... :D That is the only thing I need PLA for though.. I'm quite happy with the Z-ABS for other stuff...
