Hello everybody,
I have a problem with Z Suite 1.4.1 on Mac (El captain) Split object.
Whenever I select the command, Suite Z stops to run.
With the previous version 1.4.0, I'havent this problem
Some of you have had the same problem?
Hello everybody,
I have the same thing happening. Sucks but I use Nettfabb to cut my objects now.
I'm sure they will fix it in the next go round.
We are aware of that already, we are trying to determine what is causing that problem. However, hotfix should be released soon.
