There is a strange line in Z :)
any one know a possible reason?
thanks in advanced
Marco
1446
How many layers are in each if the lines? Is it a single layer or several? Do the two lines look identical?
If it’s several it could be an inconsistent filament diameter causing slight underextrusion for a couple of layers.
Do you see any shifting? Maybe it’s 2 minimal shifts? Pulley grub screws need tightening?
Do you see any shifting? Maybe it’s 2 minimal shifts? Pulley shrub screws need tightening?
Several layers and yes they look identical
there is a little shift of some layer
Then tighten all the grub screws on all pulleys.
