The arm or the extruder piece that actually injects the plastic is stuck towards the top in left hand corner. Also the build plate that holds the material is lifted up all the way to the top as well with the extruder. The build plate does not move even after I powered the printer on and off. This basically took place after it locked up trying to print a file. I didn’t see anything under the FAQs or Manual for troubleshooting. I also tried the calibrate function and that literally does nothing.
SW Ver 0.0.2
HW ver 01
Any help appreciated.
