Surface problem in Zsuite
Hi, I've a problem about surface in Z-suite software, after finish pre-printing process (in z-suite) the surface will not follow the actual surface from 3d design, it will become like a step or not flat surface. Refer attachment for more detail. So how I can solve this problem? any suggestion or tips? *sorry for my english :P  2205
Did you checked the STL file for flaws in Netfabb or Meshmixer? Looks like a not watertight STL.
Please upload STL file.
2216
PASSO OUTER CASING_netfabb_mm.stl
Hi, here I attached stl file (PASSO OUTER CASING).
Already check, there is no waterlight.
Yes, those are good stl files for Netfabb. Meshmixer also reported as a good files, but Rhinoceros reported some problems on OUTER_CASING: "Mesh has 343 pairs of faces that intersect with each other".
Trying Emendo, a software I was about to ditch out... Worked! (using Lattice reconstruction).
2217
2218
PASSO OUTER CASING_emendo_mm.stl
I found a surface problem with the latest update.Took me a few different tries to get it to print smoothly. I had to rotate the object slightly. Weird.
Screen%2BShot%2B2015-12-14%2Bat%2B5.51.2Screen%2BShot%2B2015-12-14%2Bat%2B5.50.3Screen%2BShot%2B2015-12-14%2Bat%2B5.50.1Screen%2BShot%2B2015-12-14%2Bat%2B5.50.2
