Has anyone else experienced the pause feature not stopping in the right place in the new Z suits .9.5?
I am setting it a 3mm and it is stopping before it gets dun with the platform , I have not run no other files
to see if it is a bad file but I have did it with this file in the earlier versions of Z suite?
thanks for your input
Clark, send email with zcode and stl file on support@zortrax.com
I have the same issue. Happens when I have many small (copied) parts. If I print just one of it, everything works fine, so no bad stl.
in .9.5 it is possible to set at a certain level?
In the documentation, it shows a dialog entry to set the level of the pause. But this does not appear on my screen. 0.9.5 on Mac OSX 10.10.1. It will insert a pause at the point selected by the slider (indicated in %) but not at a certain height.
Kyle
January 18, 2015, 4:56am
#5
I have height on mine. 9.5 Windows 7 though..
Ted
January 20, 2015, 3:42pm
#6
I had the same issue : stopped at 8%, shoud have been 56% ...
