I am trying to create a thread and screw for my next design.
What is the recommended kind of thread, minimum tolerance between the female and male and the minimum size of the outer and inner rim?
Any recommendations welcomed!
Attachment some design ideas...
axel
May 27, 2015, 8:01am
#2
I print a lot of parts with screw " male" and " female."
Not metric threads .
I drew my own thread with a rounded profile.
My method :
I drew a screw from a cylinder 10mm = screw “male” basic
I made copies ( 0.6 x -> x 4 ) to have male screw 6mm to 40mm
for each diameter , I made a copy of this screw x 1.1 = screw “female”
you must experiment with different diameters : x 1,11 ; x 1,12 , etc...
I use this copy as an object to be subtracted for the threads in the bore
Thank you. Can you explain what you mean by:
0.6 x 4?
What 0.6?? mm x 4 height? Or 4 times? Or?
6mm to 40mm?
And then when you say 1.1, x 1.12?? Do you mean scale factor or??
Do you use support for the thread printing in zsuite? What print settings do you use for support ?? 20 or 0? Or… Your thread design doesn’t need support?
Sorry I am kind of a newbie here
axel
May 27, 2015, 10:53am
#4
sorry for my bad English : I speak French and it is a bad translation !
I will explain it later
Thank you! Understood now… Standing by for feemale method
Question:
what kind of thread are you using?
what resolution are you printing at? What material?
what’s the smallest thread you had made?
Can you get away without supports for the thread?
axel
May 27, 2015, 3:27pm
#7
"what kind of thread are you using?" sorry, but i don't understand what you mean
"what resolution are you printing at? What material?" : 0,19 and 0,14 + z-abs or z-ultrat on Zortrax ; 0,20 +PLA on Witbox
"what's the smallest thread you had made?" 6mm
" Can you get away without supports for the thread?" print only without support ; print really good without support
photos : z-abs ; 0,19
axel
May 27, 2015, 3:56pm
#8
method for screws " female" : example with screws 10mm
1) I make a copy of the screw 10mm by enlarging a x1,1 factor (or 1.11 ) for to have a 11mm screw (or 11,1mm )
2) I put my 11mm screw through the object to receive the bore and the thread (see photo 1)
3) Boolean operation : I make a subtraction: I remove the screw 11mm of the object ( photo 2)
Outstanding! Thank you very much!
One question… When you enlarge the screw to be used for the Boolean operation. Do you enlarge on all axis or only on the sides (not height)…
axel
May 27, 2015, 4:58pm
#11
I enlarge on all axis
you must experiment with different scale factor : x 1,11 ; x 1,12
see my website : you will see what i print :ph34r: : http://www.support-photo.be
( actually, the model (laminator) is printed in PLA , but soon, another model (laminator) with a lot of parts in ABS) :)
Thanks you. Great prints!
Kyle
May 27, 2015, 11:39pm
#13
You can print standard threads. 60 degree angle with no support. .09 I would leave a 10 thousandths gap between nut and bolt.. That might still be a little tight.
Kyle....are you the Nut that goes with this Bolt??
:lol: :lol: :lol: :lol: :D :D :P
Cheers Mate. hehehe
Thank you all for the infoâ€¼ï¸ awesome data!
