Please contact our customer support team regarding this issue, as we will need some more info (details) from you: support@zortrax.com . Try to be as specific as you can. Also, it's always helpful for us if you provide your S/N, hardware and purchase date.
sometimes I use this method: in Z-Suite I put 'pause' in 0%. It makes printer stop just after raft is made, and then I hit "continue printing". It takes some time, the raft surface is cooling down and it's easier to take off part from the raft.
There some update in resolving issue about raft attachment to the print? i see this post is very old, but i’ve still the same problem. i thik is betther to print without raft, but i want to check if there’s a way to do it
Hi man,
Yes indeed, it has been a while. Got my second printer already, m200 plus, but nowadays you can change the 1st layer gap in Z-suite. This wasnt possible a when I posted this topic. Bigger gap should make it easier to remove raft. Good luck!
Cheers
