Hi i had zortarx m200 for 4 days and i have very frustrating problem.Two times hapened that he did not finish print it just stop on about 90 percent.I update fimware and also z suite.I am attaching image.
Please help....Also i same model print before and it was sucseful so it is not a file?
What could be a problem.I saw on support center that extruder can be filed and dirty .but i use printer just 3 days.
Please help…Also i same model print before and it was sucseful so it is not a file?
I had this problem with my M200 from new.
It turned out it was a bad SD card supplied, changed cards and haven’t had a problem since.
Changing the card is a good idea in this case. If that won't help, try to write the file directly from the Z-suite into your PC, format your SD card in FAT32 again and upload the file again.
HI Thanks,Yes i was suspect that and ichanged card and already print 3 items whitout that problem anymore.Gret,Qualty is great
Also one advice.
When it print figurenes that are around 100MM and smaler and when i put just 10 Suport on 0.14 layer is it better to set fan speed on 80 % or leave automatic .what impact will have faster speed.My goal is best posible detail extrat
