I'm getting unusual scaffolding & item in print preview, please see "Hot_print model.jpg" and "Hot_print preview.jpg".
I originally printed it with the flat base sitting on the printer's bedplate, but naturally there was lots of scaffolding due the overhanging sections, which took ages to remove & left a lot of witness marks, which reduced the aesthetic effect of the 3d logo.
So I flipped it 90 degrees, so I'd only get the scaffolding witness marks on the back of the logo, but I got the unusual print preview (of scaffolding & item) attached, and subsequently didn't proceed to print.
Could it be a CAD model error_? (I created it in 3ds-max, using unioned booleon solid objects, see "HOT.stl" attached).
Any ideas why I got this in my print preview please_?
It looks like your model have errors in mesh. Please fix the mesh of the model and try to prepere it again. Increasing .stl accuracy (more polygons) will also be helpful because geometry of the model will be visible on print.
I also suggests changing the orientation of the model, you should place the model on "flat"
.....if I can't improve/repair the CAD model, I'll just stretch & twist it in 3ds max so all the "overhangs" exceed 20 (or 30) degrees and print without scaffolding/support or only have it less than 20 (or 30) degrees.
Meshmixer is highly recommended by me too. Use it for all my SLA prints and with adjustments the custom supports are great too. Haven't tried printing custom supports yet but will soon and post results of with Zortrax auto support vs. Meshmixer autosupport (Default settings in MM I find always need to be adjusted) so its really custom support settings.
Thanks, I will certainly try Meshmixer, before think of paying for another s/w :)
